12v won't be enough. if it is an old battery try a jump start or new one. also pull the spark plugs out and try cranking it without compression first. this will get the oil pressure back up and confirm it is not seized. it may be worth putting some wd40 in the cylinders overnight if there is any suspicion of it sticking.
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
