replacing an accelerator cable
https://www.ausmini.com/forums/viewtopic.php?f=2&t=849
Author:  F.U.B.A.R [ Tue Jun 15, 2004 1:18 pm ]
Post subject:  replacing an accelerator cable
How do I get the accelerator cable out from where it goes into the firewall? I want to replace mine.
Author:  min13k [ Tue Jun 15, 2004 1:58 pm ]
it is like a bike brake cable at the top of the acellerator pedel remove it there then push through
makka
Author:  F.U.B.A.R [ Tue Jun 15, 2004 2:21 pm ]
oh ok. I will have a look. thanks.
Author:  gafmo [ Tue Jun 15, 2004 3:22 pm ]
You may find it is easier if you release the cable first from the Carby and push it through. You will then see how it goes in.
gafmo
In the Hills
Author:  Anto [ Tue Jun 15, 2004 4:42 pm ]
Unless the outer housing of the cable is stuffed just replace the inner - much easier. Just unhook it from the pedal and pull the old inner cable through from the inside (can be tricky if the inner is very worn) and then push the new inner cable through. Too easy.
Anto.
Author:  F.U.B.A.R [ Tue Jun 15, 2004 9:40 pm ]
the inner cable was rooted. I bought a new complete cable and couldn't get the old one out, so I yanked it out. It left part of it attached ot the firewall, thats why I was asking how to remove the dang thing.
cheers for the info.
Author:  drmini in aust [ Tue Jun 15, 2004 10:24 pm ]
I'd get a hammer and a long pin punch and thump it thru from inside the cabin. Probably outer's a bit rusty is all. :wink:
