It is currently Sun Aug 17, 2025 1:01 am
PostPosted: Fri Mar 21, 2014 9:32 pm
I know this has been on the forum before but I cannot find the post. I have the old rubber uni set up which has had the uni's replaced with steel unis that have plastic/nylon caps. One of the joints is no good - I can press the cups out of the caps but I don't know which uni's to buy to use to replace them. Anyone know the uni's (or the post on the forum)?
1970 MkII Cooper S
1971 Clubman GT (Replica)
71 Clubbie being worked on (1275 + lots of stuff)
Moke (1275) Awaiting restoration - Currently sheets of rust holding some mechanical bits together!
PostPosted: Fri Mar 21, 2014 9:49 pm
It is a Triumph TR6 uni, available from Karcraft and elsewhere. Common p/no is GUJ102.
Kc carry a good brand as well as cheapies. I'd go the good one... their p/no is # RTC3458/1
:wink:
PostPosted: Fri Mar 21, 2014 10:02 pm
Thanks Doc, will be chasing up a good one but car is booked for RWC on Monday so may have to use a cheapie if that's all I can get tomorrow and change it again later in week. Will also make sure that I don't lose one needle roller out of one cap as it appears PO did!
1970 MkII Cooper S
PostPosted: Fri Mar 21, 2014 10:08 pm
Kc/s good one is a GMB I think, other shops have them too.
http://www.gmb.jp/en/product/driveline/ ... joint.html
PostPosted: Sat Mar 22, 2014 6:53 am
So you can just keep the nylon ends and replace the center with a guj102 if you need to?
Dusk Blue
1964 850
PostPosted: Sat Mar 22, 2014 8:01 am
I got the GKN ones from Karcraft for $17 each. It's in my members rides thread
Yep, just press off the caps and swap it over
PostPosted: Sat Mar 22, 2014 9:58 am
Ok. Thats good to know.
The complete nylon ended uni joints are NLA now arent they??
I think I read somewhere that the manufacturer has ceased production.
Dusk Blue
1964 850
PostPosted: Sat Mar 22, 2014 10:20 am
Repco sold nylon ones many years ago but no more.
Quinton Hazell made nylon ones last but they have now gone belly up.
Se7en Industries in USA were selling some with steel caps last year, but I dunno if they still do.
Karcraft and I investigated CNC machining some steel cap ones last year, but the $ cost vs production volume beat us.
As for making plastic ones like QH did, the $$$$ for the moulds would not be worth it for the current market.
PostPosted: Sat Mar 22, 2014 10:25 am
Dont get rubber ones
John at mini king may have some nylon ones i think they were nylon when i got some complete shafts off him about 3 years ago when the rubber one went bang
Users browsing this forum: No registered users and 327 guests
