It is currently Thu Aug 07, 2025 2:23 pm
PostPosted: Sun Mar 16, 2014 7:48 pm
Hey guys!
So im trying to get off my inner pot joint and its being a pain in the ass!
Its leaking bad and thats the reason why i want to fix the seal.
Ive tried levering, crowbaring, hammering, but this thing is tough as guts.
Anyone got any ideas?
1977 Clubby!
PostPosted: Sun Mar 16, 2014 8:42 pm
IMGP2515 by k_green1310, on Flickr
IMGP2516 by k_green1310, on Flickr
Cut a thin spanner like this `Gedore' to 1.250" wide.
Then grind both sides like a cold chisel.
Put it between the diff side cover and pot joint, and hit the other end with a BFH.
Turn pot around a bit and try again if no worky...
Works for me...
PostPosted: Sun Mar 16, 2014 9:25 pm
If you were in sydney id let you borrow the proper tool slide it in and bang with a hammer
http://www.minispares.com/product/Class ... o%20search
Ive used it twice already cost me about $76 to me door from that site in uk less than a week
PostPosted: Sun Mar 16, 2014 9:48 pm
I've always used two big flat headed screwdrivers and levered it off.
PostPosted: Mon Mar 17, 2014 8:39 am
Probably broken the circlip inside & jamming a piece of it
pain in the butt when that happens
do as the good Doc says i say :-)
PostPosted: Mon Mar 17, 2014 10:35 am
Slightly off topic...
Matt,
Gafmo is having trouble getting the LH CV off the driveshaft so he can put his new S brakes on.
Usual hold driveshaft in one hand, hit CV with BFH and watch yer toes didn't work.
Any ideas? Or do we have to cut the (drum brake) CV in half to get at the *&^#^! wire circlip??
[edit]Decision made, I will drag the oxy out and do some surgery with the red scalpel.. 8)
