It is currently Sat Aug 02, 2025 6:17 am
 Post subject: Steering issues
PostPosted: Wed Jun 29, 2005 7:04 pm
Hey guys, i got a bit of a problem:
SnoBall has a HUGE issue when driving, as you accelerate hard, it veers right then when you back-off, it goes straight again!!! it isnt tourqe steer, cuz when all this happens the wheel doesnt move or tug one little bit. this wouldnt b an issue if i hadnt replaced all the bushes and engine mounts/steadys, but i have and the sterring rack cheecked out fine aswell. i'm out of ideas
Any one???
68' Morris, 1100,
Willson Automotive
Tasmania's ONLY mini Specialists
(03) 62725056
http://photobucket.com/albums/a323/the_white_one/
PostPosted: Wed Jun 29, 2005 7:27 pm
Power is going to one wheel more than the other. Check that your pot joints are all in order, along with your CV's It is torque steer just not for the right reasons :?
Aaron
PostPosted: Wed Jun 29, 2005 7:40 pm
Check the U bolts holding the steering rack on are tight. Half a turn on each one stopped my car from doing exactly the same.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Wed Jun 29, 2005 7:43 pm
cv's were checked and are fine, boots replaced.
but i dont think the pot joints have been looked @.
ive driven a FWD car with a screwed diff that only spat power to the left wheel, and it could be felt through the steering wheel. but i cant feel a thing in my car when it pull's, it just feels like its not teering when you turn into a right hand corner!!
68' Morris, 1100,
Willson Automotive
(03) 62725056
PostPosted: Wed Jun 29, 2005 9:14 pm
Check tie bars and mounts, if ok, check caster adjustment
In other words Snowball probably needs a wheel allignment
Keep shiny side up
PostPosted: Wed Jun 29, 2005 10:01 pm
Nah, it had an alignment when the buses were thrown in. and again, i reck'n id feel it through the wheel.
68' Morris, 1100,
Willson Automotive
(03) 62725056
