Sub Frames https://www.ausmini.com/forums/viewtopic.php?f=2&t=8493 |
Page 1 of 2 |
Author: | GT1360 [ Mon Jun 27, 2005 7:40 am ] |
Post subject: | Sub Frames |
OK... just want to know how many different sub freams there are.. yes I know there are wet and dry ones.. but is there differences between Mk1 and so on? |
Author: | gafmo [ Mon Jun 27, 2005 7:46 am ] |
I beleive just the two...wet and dry...4 if you include the front....except maybe the Rovers also. Here is a dry rear subby I prepared earlier ![]() |
Author: | min13k [ Mon Jun 27, 2005 7:48 am ] |
3 types of subframe wet dry and the rubber mounted fram which was from 80 81 on i think not to sure but was earlie 80's makka |
Author: | GT1360 [ Mon Jun 27, 2005 7:50 am ] |
bit of a fuzzy pic Jim.. were you having smoking withdrawals? |
Author: | gafmo [ Mon Jun 27, 2005 7:50 am ] |
![]() ![]() Try this one ![]() Any dramers dropping it..how were the bolts holding it up ![]() |
Author: | GT1360 [ Mon Jun 27, 2005 7:55 am ] |
Ok.. for the front sub. what used the single bolt bump stop.. and what used the twin bolt? |
Author: | min13k [ Mon Jun 27, 2005 7:57 am ] |
yeah eggzactly |
Author: | gafmo [ Mon Jun 27, 2005 7:57 am ] |
twin bolt on a bumper stop ![]() |
Author: | GT1360 [ Mon Jun 27, 2005 8:07 am ] |
yep... thats why I am ![]() and front bump stop twin bolt. and front bump stop hydro... |
Author: | GT1360 [ Mon Jun 27, 2005 8:08 am ] |
O and my front frame has the twin bolt one on there.. ![]() |
Author: | gafmo [ Mon Jun 27, 2005 8:10 am ] |
No joke...I have not seen twin bolted ones..cant see the reason for it |
Author: | drmini in aust [ Mon Jun 27, 2005 8:10 am ] |
OK in Oz- there are 2 wet ones, the std and MiniMatic. 1 dry type only. All these have 2 tower bolts each side. Solid mounted. In UK got these, then after `76 they got the dry type rubber mounted, and a MiniMatic (dry) rubber mounted. These had the big single hole each side. `matic ones all have a curved front rail, and the engine mount points are different. You can fit a manual onto a `matic one with spacers, but not the reverse. |
Author: | gafmo [ Mon Jun 27, 2005 8:12 am ] |
I forgot about the Matic's |
Author: | GT1360 [ Mon Jun 27, 2005 8:12 am ] |
thats why I am ![]() |
Author: | gafmo [ Mon Jun 27, 2005 8:21 am ] |
Are you saying you have twin bolts in the top arm.....or on the Sub. Here's a Dry front Subby (clean) ![]() |
