REseaming my mini k
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84930
Author:  ybot [ Tue Mar 18, 2014 12:33 pm ]
Post subject:  REseaming my mini k
Hey,
my 71 mini k has had the front and rear bumbers de seamed and i want it back to the way it was. Front looks like it will just be a new apron but the rear is giving me more of a drama.. the beaver panel is shagged and where the welded it up have warped the crap out of the rear panel at the bottom. will i have to cut out the whole bottom lip of the boot from seam to seam and replace that along with the beaver panel or is their an easier way??
Cheers Toby
Author:  peterb [ Tue Mar 18, 2014 5:29 pm ]
Post subject:  Re: REseaming my mini k
You could just fit 4 tabs to pick up bumper bolts. Just a thought.
Author:  boomini [ Tue Mar 18, 2014 8:08 pm ]
New lower boot section with the mounts for boot hinges, new rear beaver panel and new floor section will fix it as all have the seam on them... or swap yor shell for mine as im about to de seam the rear of my deluxe.. the front is easy as it is just a lip that is spot welded to the front apron. Im sure you can buy it from england.
Rodney
Author:  John Sneddon [ Thu Mar 20, 2014 1:06 pm ]
Can you tell me if your K is after YG2S1 13390 please?
Author:  ybot [ Thu Mar 20, 2014 2:39 pm ]
ive uncovered half of the number on the fire wall, but the radiator shroud was gon when i got it. i want to use pain stripper to uncover the fire wall from here. after the engine comes out this weekend ill do it and pm you john.
