It is currently Wed Aug 20, 2025 12:12 am
 Post subject: REseaming my mini k
PostPosted: Tue Mar 18, 2014 12:33 pm
Hey,
my 71 mini k has had the front and rear bumbers de seamed and i want it back to the way it was. Front looks like it will just be a new apron but the rear is giving me more of a drama.. the beaver panel is shagged and where the welded it up have warped the crap out of the rear panel at the bottom. will i have to cut out the whole bottom lip of the boot from seam to seam and replace that along with the beaver panel or is their an easier way??
Cheers Toby
 Post subject: Re: REseaming my mini k
PostPosted: Tue Mar 18, 2014 5:29 pm
You could just fit 4 tabs to pick up bumper bolts. Just a thought.
PostPosted: Tue Mar 18, 2014 8:08 pm
New lower boot section with the mounts for boot hinges, new rear beaver panel and new floor section will fix it as all have the seam on them... or swap yor shell for mine as im about to de seam the rear of my deluxe.. the front is easy as it is just a lip that is spot welded to the front apron. Im sure you can buy it from england.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Mar 20, 2014 1:06 pm
Can you tell me if your K is after YG2S1 13390 please?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Thu Mar 20, 2014 2:39 pm
ive uncovered half of the number on the fire wall, but the radiator shroud was gon when i got it. i want to use pain stripper to uncover the fire wall from here. after the engine comes out this weekend ill do it and pm you john.
Users browsing this forum: No registered users and 72 guests
