flywheel to crank
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84976
Author:  boomini [ Sat Mar 22, 2014 10:41 am ]
Post subject:  flywheel to crank
Hey guys how do you all fut your flywheels onto crank tapers?
Dry or lubricated?
Cheers guys
Author:  Minimadmarty [ Sat Mar 22, 2014 11:07 am ]
Post subject:  Re: flywheel to crank
"Do not under any circumstances use grease, oil or any lubricating product on the taper of either part.
You may however use Loctite 222# to act as a lubricant to assist the flywheel moving up the crankshaft taper. If using Loctite leave for 15 minutes before removing the nut and apply some 222# to nut and thread and retighten as before."
Don't quote me Rodney I found this on another 'how to, forum!
Sounds like you have a big day ahead of you!
Author:  Minimadmarty [ Sat Mar 22, 2014 11:12 am ]
Also found this:
http://www.minimania.com/msgThread/111398/1/1/Flywheel_problems
The forth comment suggest dry fitting!
I'm the only one up this morning, not allowed to make noise and I'm bored!
Author:  boomini [ Sat Mar 22, 2014 11:24 am ]
Haha.. s I when it falls in a heap im blaming you marty.....
I figured it was a dry fit but just thought I would ask.
Author:  Minimadmarty [ Sat Mar 22, 2014 11:31 am ]
My better half has always claimed I only have two faults;
Everything I say & everything I do!
So I wouldn't be taking my word for it Ha ha....
Author:  boomini [ Sat Mar 22, 2014 11:33 am ]
Lol
Author:  simon k [ Sat Mar 22, 2014 5:28 pm ]
When I rebuilt my motor last year, I put some STP on the crank taper and then put the flywheel on.... the motor was still on the bench in January, and I wanted to take the flywheel off again in January.
it ... would ... not ... budge
my puller is 3/4" thick, and it had about 2mm of bend across the face of it from the amount of tension that was on it. I bashed, heated, bashed, heated, left it for a week, then gave up and left it on there
use a bit of fine valve lapping paste and lap them to each other, then make them really clean and put them together dry
