It is currently Sat Aug 23, 2025 11:06 pm
PostPosted: Sun Mar 30, 2014 6:45 pm
Put a new engine in the car, but it has a backfire/crackle from the exhaust when you coast down hill in gear.
1275, 1&3/4 SU (OA6 needle, yellow spring), 256 Megadyne cam & A+ electronic disy, timing on 7 degrees and steady as.
Engine runs well, starts easy, does not run on, good power / torque, fuel mixture seems OK, no obvious exhaust leeks.
It just crackles as you coast down a hill in gear.
Any ideas what I should check next?
PostPosted: Sun Mar 30, 2014 6:50 pm
Excuse my ignorance, but is that a bad thing??
Dusk Blue
1964 850
PostPosted: Sun Mar 30, 2014 7:05 pm
What sort of exhaust are you running?
PostPosted: Sun Mar 30, 2014 7:13 pm
Basic 3 into 1 and RC40 system.
PostPosted: Sun Mar 30, 2014 7:21 pm
I had a 3 into 1 with a 2" lukey rear muffler on a 1330 with a 731 cam & twin 1 1/4". It went like stink but I had the exhaust crackle you mentioned when the weather was warm & you backed off at high revs. I just put it down to the 2" pipe being too big for the engine....but I didn't change it....I liked it! 8)
Cheers Shane
PostPosted: Sun Mar 30, 2014 7:53 pm
Usually is due to an exhaust leak somewhere.
PostPosted: Sun Mar 30, 2014 8:32 pm
No obvious exhaust leeks - block up the exhaust and the engine stalls.
PostPosted: Sun Mar 30, 2014 8:35 pm
I just bought an A45 AMG Mercedes... It does the same thing in sports mode!... Cost a lot of money to hear that sound ;)
Timing not optimised?
PostPosted: Sun Mar 30, 2014 8:40 pm
I read somewhere that can be caused by running a bit rich - basically unburnt fuel popping off in the exhaust
PostPosted: Sun Mar 30, 2014 8:45 pm
I will check the mixture with the AF meter, but I don't think it is that far out.
Unless it is a combination of the mild cam & a little rich.
PostPosted: Sun Mar 30, 2014 8:57 pm
Thats a great sound why change it
PostPosted: Mon Mar 31, 2014 12:19 am
The old rule of thumb
Backfire from Carby is lean
Backfire from Exhaust is Rich
Could also be dozens of other things but start there first.
PostPosted: Mon Mar 31, 2014 4:17 am
MAnifold gasket ?? Blown not sealing brothers car use to back fire out the exhaust when he took foot off accelerator
PostPosted: Mon Mar 31, 2014 5:07 am
It is most likely getting air in the exhaust somehow.
Could be past the manifold gasket, past the slip joint if there is one or even past the valve guides if they are worn enough.
Manifold gaskets somtime leak under vacuum and not under pressure.
