It is currently Wed Aug 06, 2025 11:40 am
 Post subject: Inline PCV Valve
PostPosted: Sun Mar 23, 2014 9:26 am
I've tried searching with no luck , but can someone throw up a pic & part No , (or the thread ) of an inline PCV Valve that others have used before , I think it was Doc's .
Cheers .
 Post subject: Re: Inline PCV Valve
PostPosted: Sun Mar 23, 2014 9:33 am
IMGP2158 by k_green1310, on Flickr
I got mine from Repco for $27 but they are cheaper on the web.
http://www.eziautoparts.com.au/pcv-valve-pcv-013.html
PostPosted: Sun Mar 23, 2014 9:41 am
Perfect , thanks Doc .
PostPosted: Sun Mar 23, 2014 12:58 pm
I got mine from the local auto supplier for $16. They even had it on the shelf.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Mar 23, 2014 3:05 pm
= They are common, fit a Toyota.
PostPosted: Sun Mar 23, 2014 6:13 pm
I need to install one if these. How does it all get plumbed in.
PostPosted: Sun Mar 23, 2014 7:09 pm
It goes between the breather and the inlet manifold, same as it would on a Cooper S or other 1275 without an SU vac port.
Works like the S breather but no parts to replace.
You are supposed to use with a Cooper S/1100S breather cap but I found they work fine with a sealed cap.
Rocker cover needs to be sealed, unless you are using it as the breather like I do.
see the ezyautoparts link I gave above for flow direction.
PostPosted: Sun Mar 23, 2014 8:05 pm
There is also a PCV-014 which has 9.6mm one end (to suit vac hose) and 12.7mm the other end that suits heater hose which will connect straight onto the mini breathers.
Steve
Users browsing this forum: No registered users and 35 guests
