Inline PCV Valve
https://www.ausmini.com/forums/viewtopic.php?f=2&t=84987
Author:  goodie [ Sun Mar 23, 2014 9:26 am ]
Post subject:  Inline PCV Valve
I've tried searching with no luck , but can someone throw up a pic & part No , (or the thread ) of an inline PCV Valve that others have used before , I think it was Doc's .
Cheers .
Author:  drmini in aust [ Sun Mar 23, 2014 9:33 am ]
Post subject:  Re: Inline PCV Valve
IMGP2158 by k_green1310, on Flickr
I got mine from Repco for $27 but they are cheaper on the web.
http://www.eziautoparts.com.au/pcv-valve-pcv-013.html
Author:  goodie [ Sun Mar 23, 2014 9:41 am ]
Perfect , thanks Doc .
Author:  ryan [ Sun Mar 23, 2014 12:58 pm ]
I got mine from the local auto supplier for $16. They even had it on the shelf.
Author:  drmini in aust [ Sun Mar 23, 2014 3:05 pm ]
= They are common, fit a Toyota.
Author:  kiwiinwgtn [ Sun Mar 23, 2014 6:13 pm ]
I need to install one if these. How does it all get plumbed in.
Author:  drmini in aust [ Sun Mar 23, 2014 7:09 pm ]
It goes between the breather and the inlet manifold, same as it would on a Cooper S or other 1275 without an SU vac port.
Works like the S breather but no parts to replace.
You are supposed to use with a Cooper S/1100S breather cap but I found they work fine with a sealed cap.
Rocker cover needs to be sealed, unless you are using it as the breather like I do.
see the ezyautoparts link I gave above for flow direction.
Author:  justminis [ Sun Mar 23, 2014 8:05 pm ]
There is also a PCV-014 which has 9.6mm one end (to suit vac hose) and 12.7mm the other end that suits heater hose which will connect straight onto the mini breathers.
