Gearbox ID https://www.ausmini.com/forums/viewtopic.php?f=2&t=84999 |
Page 1 of 2 |
Author: | carter [ Sun Mar 23, 2014 3:21 pm ] |
Post subject: | Gearbox ID |
G'day fellas picked up a couple of gboxes yesterday wandering what they are.... 22g1832. 5/3239 22g1128. 30/1979 22g1832. E641 What do these belong too? Cheers |
Author: | drmini in aust [ Sun Mar 23, 2014 3:44 pm ] |
Post subject: | Re: Gearbox ID |
22G1832 is a common Oz Clubby rodchange box, small journal idler gear (ie NOT A+). 22G1128 is a 4 synchro remote box, could be Mini-K, Mk2S, 1098 Clubby, (or 1098 Moke if it has a puddin' stirrer shift on it). |
Author: | carter [ Sun Mar 23, 2014 3:50 pm ] |
Thanks doc. No idea what the other is? I think it is mk 2 s box has the s flanges on it. |
Author: | drmini in aust [ Sun Mar 23, 2014 3:52 pm ] |
If it has S flanges it may be an S box or been used in one, count the teeth on the 1st motion shaft. 18T = Mk2S or GT gear ratios 17T = common K etc ratios. or check part number on cluster gear, 22G1040 = Mk2S or GT. |
Author: | Morris 1100 [ Sun Mar 23, 2014 3:57 pm ] |
Didn't the Moke box have Hardy Spicer outputs too? |
Author: | drmini in aust [ Sun Mar 23, 2014 4:55 pm ] |
Morris 1100 wrote: Didn't the Moke box have Hardy Spicer outputs too? I dunno, I've never owned one that vintage. Both mine were 998s with pot joints. |
Author: | TK [ Sun Mar 23, 2014 5:16 pm ] |
Dad's 1100 Moke with 1128 had hardy spicer uni's, 1972 vintage. |
Author: | 69k1100 [ Sun Mar 23, 2014 5:35 pm ] |
Remembering that remote boxes are in the region of 40+ years old so anything goes in terms of output shafts/diffs/ even the gearset. Get a part number or count the teeth. |
Author: | John Smidt [ Sun Mar 23, 2014 5:41 pm ] |
Morris 1100 wrote: Didn't the Moke box have Hardy Spicer outputs too? They sure did, You are spot on again Morris 1100 |
Author: | goodie [ Sun Mar 23, 2014 6:11 pm ] |
John Smidt wrote: Morris 1100 wrote: Didn't the Moke box have Hardy Spicer outputs too? They sure did, You are spot on again Morris 1100 This Morris fella , he's like the kid that only shows up for school twice a week , then gets 100% in his school exam ![]() ![]() ![]() |
Author: | carter [ Sun Mar 23, 2014 8:21 pm ] |
Ok thanks for all ya help fellas. Ill count the teeth and see what I have cheers. |
Author: | Bubbacluby [ Sun Mar 23, 2014 9:08 pm ] |
drmini in aust wrote: Morris 1100 wrote: Didn't the Moke box have Hardy Spicer outputs too? I dunno, I've never owned one that vintage. Both mine were 998s with pot joints. oh oh pick me pick me..... I have one and yes they did ![]() The GT gearbox has a code stamped into the side of the gearbox signifying it has close ratio gears (just cant remember the code). I would assume the Cooper S does also. |
Author: | Morris 1100 [ Sun Mar 23, 2014 9:34 pm ] |
The Mk1 Cooper S has a number like an engine number stamped on the box, something along the lines of 9Y/1234 (don't make me go out to the shed to look! The Mk2 has a different code. (but I don't have one here to check!) The normal cars have a 12345/6 type of number. These numbers will somehow define what the box was when it left the factory. I will take some photos tomorrow of what I have. |
Author: | carter [ Mon Mar 24, 2014 2:26 pm ] |
so does anyone know what the third box is off? 22g1832. E641..........i counted the teeth on the pinion and theres 18 teeth. the box is really hard to turn over though. |
Author: | drmini in aust [ Mon Mar 24, 2014 2:50 pm ] |
It's a rodchange box as I said. 18T pinion = a 3.44 diff = Clubby (shaped car) of some sort. Could be from any of them, really... |
