It is currently Thu Jul 24, 2025 10:29 am
 Post subject: Cooper s crank?
PostPosted: Wed Mar 26, 2014 5:17 pm
G'day fellas have a couple of cooper a cranks here and a couple large journal 1100s cranks. Saying they need a refrains what are they worth?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: Cooper s crank?
PostPosted: Wed Mar 26, 2014 5:47 pm
Crack test em first, they might be doorstops.
Also measure them, one that's std or at -.010" is worth lots more than one that's at -.030" or -.040".
Bear in mind a crank regrind on all journals is around $200 at many places now.
PostPosted: Wed Mar 26, 2014 5:51 pm
How would you measure them doc? A set of veneer calipers ?
1970 mini k
1975 leyland
PostPosted: Wed Mar 26, 2014 5:54 pm
Yeah that will tell you the size it's at, but if you want to measure wear, a 1"-2" micrometer is more accurate.
PostPosted: Wed Mar 26, 2014 5:58 pm
Cheers doc. What price range would I be looking at it I wanted to sell them ranging from minimum wear 10 thou to only one grind left? Both the a cranks and the other normal 1275 cranks
1970 mini k
1975 leyland
