Cooper s crank?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85037
Author:  carter [ Wed Mar 26, 2014 5:17 pm ]
Post subject:  Cooper s crank?
G'day fellas have a couple of cooper a cranks here and a couple large journal 1100s cranks. Saying they need a refrains what are they worth?
Author:  drmini in aust [ Wed Mar 26, 2014 5:47 pm ]
Post subject:  Re: Cooper s crank?
Crack test em first, they might be doorstops.
Also measure them, one that's std or at -.010" is worth lots more than one that's at -.030" or -.040".
Bear in mind a crank regrind on all journals is around $200 at many places now.
Author:  carter [ Wed Mar 26, 2014 5:51 pm ]
How would you measure them doc? A set of veneer calipers ?
Author:  drmini in aust [ Wed Mar 26, 2014 5:54 pm ]
Yeah that will tell you the size it's at, but if you want to measure wear, a 1"-2" micrometer is more accurate.
Author:  carter [ Wed Mar 26, 2014 5:58 pm ]
Cheers doc. What price range would I be looking at it I wanted to sell them ranging from minimum wear 10 thou to only one grind left? Both the a cranks and the other normal 1275 cranks
