It is currently Mon Jul 21, 2025 12:44 am
PostPosted: Sun Mar 23, 2014 12:28 pm
Ive searched and search, but i just need to know the closet paint colour to original for a "1964 850 van engine"
i dont care what the original colour was called, just whats the closest to the colour avaliable in australia?
cheers.
[email protected]
PostPosted: Sun Mar 23, 2014 10:15 pm
I did read that a similar colour might have been called "Sherwood Green"
As you can see in the picture, it's not the correct colour! Image I am still on the hunt for a better match.
[email protected]
PostPosted: Mon Mar 24, 2014 3:51 am
Iv got a couple of early 850 engines sat in the shed and seem to be the usuall bmc green. I got a litre of middle bronze green made up in a satin finish for a wolseley engine that im rebuilding its pretty much near the same give or take 40 odd years of heat and oil. wattyl do the same colour but i ended up getting a paint mob to mix it for me as it confused the bloke in bunnos ;). Not sure when the colour changed to the metalic green
66 Van 1275
69 K Sedan
69 K Van Teabag
66 austin Countryman
68van
PostPosted: Tue Mar 25, 2014 12:08 am
The Mini King
I am fairly sure the colour changed when The engine number prefix changed
from 8AM To 8YU, Before someone points it out, :wink: Yes I know there are more letters after the 8
but it is the A or the Y that makes the diff in this case
PostPosted: Tue Mar 25, 2014 8:40 am
John, I wonder did the Mini Van even get the 8AM motor? All the ones I have seen have the 8Y/U motor.
But I suppose the earliest one I have seen is number 1301 so there is still 800 before it that might have the UK motor.
Anyway, there is a fair chance that the colour would be the Australian colour and not the UK one.
PostPosted: Tue Mar 25, 2014 9:07 am
Thanks for your help, my numbers are 8y/U/H.
I'm now thinking because I'm installing a more reliable 1275cc I will paint the the darker olive green to keep the colours more correct. Cheers.
[email protected]
PostPosted: Tue Mar 25, 2014 11:10 am
Might not be right colour but it really does look good.
An 8AM motor, does it start better in the morning? (sorry, couldn't resist it)
PostPosted: Thu Mar 27, 2014 7:12 pm
Kind of the same topic, but is there a single colour the 1100s (1275) was or are there lots of colours for that too? 12YD Ta H.
[email protected]
PostPosted: Thu Mar 27, 2014 7:17 pm
Couple of 1100S blocks I have here look to be same as Cooper S light green metallic.
Mini King's enamel paint is a pretty good match.
PostPosted: Thu Mar 27, 2014 7:31 pm
Great, thanks. Must be the same as the 850 was originally.
[email protected]
