Interesting engine mounting bracket https://www.ausmini.com/forums/viewtopic.php?f=2&t=85063 |
Author: | Morris 1100 [ Fri Mar 28, 2014 8:04 pm ] |
Post subject: | Re: Interesting engine mounting bracket |
Morris 1100 |
Author: | mickmini [ Fri Mar 28, 2014 8:19 pm ] |
Morris 1100 wrote: Morris 1100 stop quoting your name |
Author: | Curly [ Fri Mar 28, 2014 8:24 pm ] |
Morris 1100 wrote: Morris 1100 Thanks, I'm presuming it will still work in a Mini situation ![]() Did the Morris 1100 have a different engine mount with 3/8" bolts or did the 5/16" ones just rattle around? |
Author: | m1100s [ Fri Mar 28, 2014 9:23 pm ] |
Morris 1100 had two Morris Minor mounts attached to a plate behind the timing cover, one front one back. ![]() You can see the front one just under the alternator, just. Ash. |
Author: | TheMiniMan [ Fri Mar 28, 2014 9:56 pm ] |
yes morris 1100 the early 850s had a piece of sH1tmetal excuse for a thing they halfar$ed that nearly all of them cracked before they even left the production line,,, ok maybe didn`t crack that quick but not far fromt it ![]() hence the new design you one show here but yes with the captive nuts for the mount |
