It is currently Sat Jun 28, 2025 3:58 am
PostPosted: Sat Mar 29, 2014 6:56 pm
A hint I ran across a little while ago.
For rusty chrome parts, within reason.
Take a piece of aluminium foil form the kitchen drawer, wet it with water and rub. Make sure you have washed all the dirt off the parts first to avoid unnecessary scratching.
I didn't believe it at first, but it can work well.
Brian
PostPosted: Sat Mar 29, 2014 8:27 pm
I'll give it a go! :lol:
PostPosted: Sat Mar 29, 2014 8:28 pm
Steel wool and soap pads works as well box of no name stuff about $3 at woolies or coles
PostPosted: Sat Mar 29, 2014 8:30 pm
Lmfao at the pic
PostPosted: Sat Mar 29, 2014 8:34 pm
drjbeam wrote:
Lmfao at the pic
You won't be laughing so hard once I clean the rust up! :lol: :lol:
PostPosted: Sat Mar 29, 2014 8:46 pm
Still got some useable parts on it...
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sat Mar 29, 2014 8:49 pm
I love the positive attitude Rodney :wink:
PostPosted: Sat Mar 29, 2014 9:36 pm
Aluminum foil works way better than anything else I've tried, if there is any pitting or rust the alloy will shed and little pieces will fill the holes.
I've had chrome that I thought would be nothing but scrap come up nice with just foil, I just crunch it up into a tight ball and rub it over the surface dry.
PostPosted: Sat Mar 29, 2014 10:31 pm
Die Die Die!!
this stuff looks interesting
http://strongarmbrand.com/SitePages/QT/
PostPosted: Wed Apr 02, 2014 11:00 am
Aluminium Foil with Coke is supposed to be the best combination. I have seen it used and worked great.
1970 MkII Cooper S
1971 Clubman GT (Replica)
71 Clubbie being worked on (1275 + lots of stuff)
Moke (1275) Awaiting restoration - Currently sheets of rust holding some mechanical bits together!
PostPosted: Wed Apr 02, 2014 3:50 pm
OK...I have Aluminium Foil covering my head and I have opened and drunk a can of Coke with a dash of Bourbon...what happens now? :lol:
PostPosted: Wed Apr 02, 2014 5:48 pm
Open another can of Coke and add a slightly larger dash of Bourbon :D
Repeat until you pass out.....
PostPosted: Wed Apr 02, 2014 6:40 pm
I don't think that will end well
when he wakes up and looks in the mirror
