Any Fitment Issues with LCB/RC40 on Puddin Stirrer? https://www.ausmini.com/forums/viewtopic.php?f=2&t=85135 |
Author: | Hunter2 [ Fri Apr 04, 2014 4:01 am ] |
Post subject: | Any Fitment Issues with LCB/RC40 on Puddin Stirrer? |
Before taking the plunge...are there any particular fitment issues installing an LCB and RC40 with 'Puddin Stirrer' transmission with rubber/steel inner joints? I ask because there was a bit of fiddling required to ensure clearance between stock exhaust and QH joints (since replaced with standard). |
Author: | drmini in aust [ Fri Apr 04, 2014 6:56 am ] |
Post subject: | Re: Any Fitment Issues with LCB/RC40 on Puddin Stirrer? |
Hi Rick, I believe there is a problem with room when fitting a Maniflow LCB and rubber cross U/Js, rumour has it a pipe needs denting in for clearance. I know it's more work but I would be fitting pot joints & shafts instead... as the rubber ones are not durable these days. Alternative (but costly) is fit Hardy Spicers, they will slide onto the splines of your existing driveshafts. [edit] If you want to keep rubber U/Js I would fit a Maniflow freeflow header instead. |
Author: | timmy201 [ Fri Apr 04, 2014 7:28 am ] |
Maniflow/minispares/minimania stock two different versions - one is shaped slightly different to fit around the rubber joints. They're double the price though! Normal http://www.maniflow.co.uk/index.php?vie ... oduct=1319 Alternate http://www.maniflow.co.uk/index.php?vie ... oduct=1122 The Freeflow Cooper style manifolds fit on fine with the rubber joints http://www.maniflow.co.uk/index.php?vie ... oduct=1507 |
Author: | Hunter2 [ Fri Apr 04, 2014 8:14 am ] |
Thanks for the quick responses...I have new pot joints and related drive shafts so that is the way I'll go! |
