It is currently Fri Jul 18, 2025 2:52 pm
 Post subject: what is my mini?
PostPosted: Fri Apr 04, 2014 11:00 pm
Hey I was Wondering if somebody can give me details of my mini, it is 12/72 built, body number prefix of yg2s7 and as far as I can tell the paint looks to be original colour gambier turquoise other numbers on the plate are 1-2-3-4-5a-7-8-10a-1, 14-15-20-22-25-26 are these option and trim level numbers? It has a clubbie front and dash but firewall and rear seat back panel look to be like a roundnose, where all the early clubman's like this or has the nose been changed it has been in a front end crash at some point in its life and had an 1100 engine fitted to it with a remote change box when I bought it, is this the correct motor? Any help with identification of my mini would be greatly appreciated and also will determine how original I keep it
engine conversion thread http://www.ausmini.com/forums/viewtopic.php?t=79201
build thread http://www.ausmini.com/forums/viewtopic ... xe&start=0
 Post subject: Re: what is my mini?
PostPosted: Fri Apr 04, 2014 11:33 pm
I'm pretty sure those numbers are ADR rules/laws that the car complies with when it was built. On that plate it will proabbly say "Leyland mini" that will tell you what model it is.
PostPosted: Fri Apr 04, 2014 11:39 pm
It just says mini. Above the build date no Leyland or morris name anywhere
PostPosted: Sat Apr 05, 2014 12:05 am
Just looked through a few sites and could only find yg2s6 and yg2s8
PostPosted: Sat Apr 05, 2014 6:26 am
YG2S7 Body prefix on the data/Vin plate relates to a
Mini Clubman YDO 22
Engine No should start with 1001 or 1004
1098 cc engine
Alpine Mountains full of Mini's and Moke's.
PostPosted: Sat Apr 05, 2014 7:19 am
Online
re the firewall and rear seat panel, early Clubbie to about 1974? had these holes in, so they could be rotodipped in the Zetland paint shop.
After production moved to Enfield these holes were dropped, also the firewall got reshaped to clear the donut air filter used on the HS4 carby then fitted.
PostPosted: Sat Apr 05, 2014 9:15 am
They didn't remove the rotodip spit holes till around 1977.
The car is a base Mini Clubman.
PostPosted: Sat Apr 05, 2014 10:54 am
My first mini was a 72 clubman. YG2S75493 engine no.10016058
It had the spit holes. I think the other differences with the 72 base model ones are the "mini clubman" boot badge, and the flat topped rear seat back , If im not mistaken.
It was originally a blue not too far from my dusk blue 850 from memory. But had been resprayed red.
Drums all round is a base model clubman thing too yes??
Dusk Blue
1964 850
PostPosted: Sat Apr 05, 2014 12:46 pm
Online
The only Clubbys that got discs here were the GT (7.5") and the 1275LS (8.4").
PostPosted: Sat Apr 05, 2014 1:14 pm
YG2S7, Morris Mini Clubman was the replacement for the Morris Mini K, the upper market vehicle of the fleet at that time and built from June 1971 to December 1972 when it was replaced with the 021A2S2M10 version.
Is your car later than YG2S7 8518 by any chance?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Sat Apr 05, 2014 9:26 pm
I wouldn't really call it the upper market vehicle... that was the clubman GT (YG2S8)
It was just the standard model mini of the time. There was the poverty model YG2S6 and then the upper class model YG2S8. YG2S7 was the one in between. Yes the equivalent model of the mini K which it replaced.
PostPosted: Sun Apr 06, 2014 3:11 am
Mine is later but not by much 85**, any reason why you ask?
PostPosted: Sun Apr 06, 2014 7:23 am
Morris Mini Clubman??
Is that a typo?
My old YG2S7 clubby didnt have any morris badging on it.. it had the little leyland australia badges on the sides too
Dusk Blue
1964 850
Users browsing this forum: drmini in aust and 99 guests
