It is currently Fri Jul 18, 2025 11:37 am
 Post subject: Rust kill
PostPosted: Fri Apr 04, 2014 9:24 am
Noob question
What do people recommend for rust treatment?
Is there one product that is good for everything or different ones for
differnt areas?
 Post subject: Re: Rust kill
PostPosted: Fri Apr 04, 2014 10:09 am
A bit of everything - where are you looking at?
I've had very good success with a wirewheel and POR-15 paint - expensive, but does the job beautifully. I've used POR on my floorpans and around my master cylinders, as I know that brake fluid strips most paint, but it doesn't seem to affect POR.
I've used the RustKill paints on some of my component like my radiator, radiator brackets, engine steadies etc. and I'm pretty happy with it. Again, I just ran over everything with a wire wheel, then sprayed over. Only place where it has failed is on the top radiator bracket when I didn't bolt it down hard enough, and a few weeks of hot coolant weeping out caused it to bubble.
I've used rust converters, but they don't do the same job as a rust dissolver and new paint, I've never got them to work as well as I would have liked.
PostPosted: Fri Apr 04, 2014 12:40 pm
There is also KBS Rust Seal - very similar to POR15 but Aussie Made and there are more colours to choose from. A bit cheaper than POR 15 as well.
http://www.kbs-coatings.com.au/kbs-rustseal
KBS/POR is good stuff, it's self levelling so it leaves a good finish even if you brush it. I remember seeing someone on here who had sprayed a subframe with black POR15 using a cig little beaver sprayer - the finish was very glossy!
Just be aware that KBS/POR degrades when exposed to UV so you need to overcoat it - not really a problem if you are doing rust repairs which will be painted over anyway though.
+ Too many other classics
PostPosted: Sat Apr 05, 2014 11:30 pm
Phosphoric acid is my recommendation I use Bondall brand available at bunnings around $25 per liter. It will burn your skin as good as it kills rust!Image
[email protected]
PostPosted: Sun Apr 06, 2014 12:58 am
I have been using 2 products lately
Galmet Ironize http://www.itwpf.com.au/galmet/product. ... oductid=13
I apply it with a paint brush for small spots and heavy duty rust. Can be painted over. Just slap it on and when it dries you can paint over it.
Supacheap septone stuff. http://www.supercheapauto.com.au/online ... 0015#Cross
Have to be careful to only apply it to the rust and not clean metal or paint because it stays sticky. Is a bit more toxic as well so you need to use PPE.
PostPosted: Sun Apr 06, 2014 8:25 am
You need to wash the Septone stuff off with water and then metho.
PostPosted: Sun Apr 06, 2014 9:23 am
Another Por15/KBS type of thing. Was reading about it over the weekend...
http://www.rustbullet.com.au/
