SU Needle Help https://www.ausmini.com/forums/viewtopic.php?f=2&t=85147 |
Author: | 1018cc [ Sat Apr 05, 2014 1:11 pm ] |
Post subject: | SU Needle Help |
Hey everyone, Just after some advice on which way to go with needles in my mini. Currently running GY and they were a bit lean mid range, have some borrowed Ms in there now and slightly better but still lean mid range (1800 - 2800rpm). It is fine just off of idle and from 3,000ish rpm up in both cases. I have narrowed it down to DU, L or EQ with I think the EQ leading the charge for the next try <- open to suggestions on what to try next, even if it isn't on my list of possibilities. Engine spec: 998+0.020" ported 12G295 with biggest valves that'll fit ported inlet manifold Maniflow LCB Twin HS2s with K&Ns Thanks. |
Author: | gtogreen1969 [ Sat Apr 05, 2014 1:51 pm ] |
Post subject: | Re: SU Needle Help |
Have you seen this chart? http://www.google.com/url?sa=t&rct=j&q= ... tXCMr6rxKQ |
Author: | 1018cc [ Sat Apr 05, 2014 6:11 pm ] |
Thanks for that. I'll have a bit of a play and see what it comes up with. |
Author: | simon k [ Sat Apr 05, 2014 6:26 pm ] |
depends on the position of the dashpot pistons - is it lean under load or gentle acceleration or??? http://www.morrismini.com/SUNeedlesV2.a ... &size=.090 |
Author: | 1018cc [ Sat Apr 05, 2014 6:38 pm ] |
Hey Simon, it's lean under both gentle acceleration and under hard accel. It is more noticeable under hard accel. |
Author: | leonrjohnson [ Sat Apr 05, 2014 10:45 pm ] |
This tool is GREAT also for comparing needles: http://www.mintylamb.co.uk/suneedle/ I have used it heaps, and it works. |
Author: | 1018cc [ Sun Apr 06, 2014 6:59 am ] |
That's the site that I have been using to come up with my original list of possibilities. Its a good site. |
Author: | drmini in aust [ Sun Apr 06, 2014 9:15 am ] |
I've often found if the Ms are too lean, AH2 works fine. Stick em into mintylamb site and have a look. ![]() |
Author: | 1018cc [ Sun Apr 06, 2014 6:20 pm ] |
Thanks for the help guys. The clutch in the brides car is haddit so I spent some time today getting the mini in top shape and whipped the needles out and spent some time with some sandpaper and the drill around stations 4-7 with blending 3 to 4 and 7 to 8. Must say it worked out superbly as I picked a few dimensions from a couple of the other needles people suggested and worked towards a blend of GY and an average of the others to get something that feels perfect everywhere and idles beautifully. |
