Tap & Die Set
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85175
Page 1 of 3
Author:  Minimadmarty [ Sun Apr 06, 2014 7:34 pm ]
Post subject:  Tap & Die Set
Does anyone do a Mini specific Tap & Die Set?
If not, what would people recommended?
Author:  Mick [ Sun Apr 06, 2014 7:47 pm ]
Post subject:  Re: Tap & Die Set
1/4, 5/16, 3/8 UNF
1/4, 5/16, 3/8 UNC
These would be my most commonly used sizes. Intermediate taps are fine for most sizes, although I would get a finishing tap in time for the UNCs and 1/4 UNF as they are good for cleaning out drilled stud holes of crap before assembly. You won't use the larger UNCs very often however, except for studs.
Author:  Minimadmarty [ Sun Apr 06, 2014 8:30 pm ]
Cheers Mick,
My main reason for a Tap & Die will be for cleaning out stud hole. How can I tell if I need UNF or UNC? Should I use a drilling oil or just blow the crap out with compressed air?
Author:  Mick [ Sun Apr 06, 2014 8:39 pm ]
You can tell UNF from UNC just by looking at the thread in the hole. The UNC will look a whole lot more coarse than UNF.
Compare one end of a head stud with the other end and you can compare the two threads.
Blowing htem out helps, so does a little lubrication through thread cutting compund or oil in a pinch, but the tap or die does all the work of removing the junk from the threads that compressed air won't touch. That way your studs screw in with two fingers all the way home on assembly.
Bolts going into aluminium are UNC, the head studs are UNC, the manifold studs are UNF. I think the thermostat threads are also UNC.
Gotta be careful though, they are cutting tools, you you can cause some damage if you don't go carefully. They are also HSS material, so they will snap off if you drive the smaller ones too hard. Very difficult to remove and nearly always causing damage as retrieved.
Do a little googling on threads, you might need a few pointers involving a few pictures to understand what is going on, how to pick a thread and simple fixes for deburring damaged threads.
Author:  Minimadmarty [ Sun Apr 06, 2014 8:50 pm ]
Cheers again Mick,
Googling I shall go, might also try the University of YouTube :D
Author:  Babes [ Sun Apr 06, 2014 9:16 pm ]
Marty I will show you my kit when you come to collect the manuals, I have never had to use anything not in it.
Author:  Minimadmarty [ Sun Apr 06, 2014 9:39 pm ]
Cool, I text ya' tomorrow to organise a time :D
I'll bring the Bini 8)
Author:  drmini in aust [ Mon Apr 07, 2014 7:34 am ]
I would perhaps add a 7/16" UNF tap for the main bearing bolt holes...
Author:  9YaTaH [ Mon Apr 07, 2014 10:50 am ]
Especially in blind holes, one tiny twist, then snap :oops:
(I haven't done that of course, just seen it happen :lol: )
Author:  boomini [ Mon Apr 07, 2014 7:41 pm ]
Your gonna have a mechanics workshop full of tools by the time your finished marty
Author:  Minimadmarty [ Mon Apr 07, 2014 9:23 pm ]
Heaven 8)
Author:  Minimadmarty [ Mon Apr 07, 2014 9:36 pm ]
Based on advise I made this purchase today :D
Made by Kincrome its a 24 pieces set I guess it's a good start! Also brought myself some big arse spanners 8)
Author:  Diesel27 [ Mon Apr 07, 2014 11:20 pm ]
I hate to sound anal but I have only ever used ISO recognised type brands like P&N or Sutton etc
Author:  Minimadmarty [ Tue Apr 08, 2014 7:14 am ]
Great advise thank you. I just picked up a cheaper set to start off with if I start using it a lot I'll upgrade as required. I do like Sutton drill bits :D
Author:  drmini in aust [ Tue Apr 08, 2014 8:59 am ]
Same here, recognised brand (eg P&N, Sutton, etc) taps and dies are thread ground to size after heat treatment, and made from quality tool steel or HSS. The el cheapo ones are not.
Quality costs money but for cutting tools, is worth it. :wink:
Page 1 of 3 All times are UTC + 10 hours
