Welcome to the world of minis dsoan, tell us a little more if you can about your new mini!
With your door handle, there's about four different styles from Sliding window type, to Australian production type to clubman and then rover. We'll need to work out what it is. They each have their own problems.
With the oil leak, yeah its typical when you get an engine of a few miles or hours on the clock that it will start to have an oil leak issue. Sealant isn't the way you will attack it. Oil will just push it out of the way and continue on to the garage floor, there's pretty well no exceptions to this rule no matter how small it is in. There will be a small gasket or seal somewhere which will need to be replaced. They're not difficult to identify and not expensive, pictures tell a thousand words on here too.
You will need to develop this a little further and identify where it is coming from, if its a gasket or oil seal. The oil will be on the bottom of the engine, but try to track it back up the engine block to its source.
_________________ SooperDooperMiniCooperExpertEngineering
