Gearbox ID Please. https://www.ausmini.com/forums/viewtopic.php?f=2&t=85183 |
Author: | drmini in aust [ Mon Apr 07, 2014 4:13 pm ] |
Post subject: | Re: Gearbox ID Please. |
1st one according to Mini King book is rodchange with small idler bearing, 2nd one is a more common Oz rodchange, small idler bearing, same ratios as a Mini K etc remote box. Essentially both boxes are much the same if my books are right. |
Author: | WasabiPimpNinja [ Mon Apr 07, 2014 4:23 pm ] |
Thanks for that Doc. Managed to find a bit of info online that pretty much says the same thing. Looks like I'll go the one with less wear ![]() Thanks again. Cheers, Keels. |
Author: | John Smidt [ Mon Apr 07, 2014 6:56 pm ] |
WasabiPimpNinja wrote: Thanks for that Doc. Managed to find a bit of info online that pretty much says the same thing. Looks like I'll go the one with less wear ![]() Thanks again. Cheers, Keels. To check Your ratio's count the teeth on the crown wheel and the pinion also the teeth on 4th gear cluster and first motion shaft or look for part number on cluster between 3rd and 4th gear 22G931 std 22G1040 Cooper S |
Author: | drmini in aust [ Mon Apr 07, 2014 7:04 pm ] |
When I said `ratios' in my previous post, I meant internal gearset, not the diff ratio. Most all rodchange boxes here had a 3.444:1 diff, but a Mini K remote box was 3.765 (early) or 3.647 (most, and also 1098 Clubby). |
Author: | John Smidt [ Mon Apr 07, 2014 7:43 pm ] |
The Reason I suggested Counting The teeth, Is because over the Years people may have changed the ratios Gear or diff for one reason or another, it does not hurt to Know exactly what You have |
