It is currently Fri Jul 25, 2025 11:37 pm
PostPosted: Mon Apr 07, 2014 6:30 pm
Hi what is the size of tallest item I can fit in the back of a panelvan before it touches the roof?
anyone please?
Davids Automotive Detailing: 0467 629 947
Professional Buff & Polish- Scratch, swirl removel
https://www.facebook.com/pages/Davids-A ... n=timeline
PostPosted: Mon Apr 07, 2014 6:50 pm
Getting in the rear doors will be the issue. The roof is higher than the opening.
PostPosted: Mon Apr 07, 2014 7:02 pm
Thanks mate.
The item I have is 850mm tall and needs to stand upright.
PostPosted: Mon Apr 07, 2014 7:32 pm
Just measured the opening on my van and your out of luck. Its 780 mm
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Apr 07, 2014 8:44 pm
Up near the back of the seats, the front of the load bay the roof may just be that big but probably not...how long or wide is your item?
PostPosted: Mon Apr 07, 2014 8:45 pm
You could just cut the roof off and make it a mini ute.
PostPosted: Mon Apr 07, 2014 10:34 pm
about 350mm x 350mm.
So the opening is the smallest height right?. Its for a gerni pressure cleaner and I need a min of 820mm once its sat in the van. Id be able able to get in thru the opening but hoping it would stand up right once in the back of the van at 820mm. Thanks for your help
How wide are they? 1m?. ive had a few vans over the time but would love to work out of a mini
PostPosted: Tue Apr 08, 2014 1:41 pm
I can measure mine up for you on Thursday if you like, it's just a bit far away at the moment.
Opening is definitely the shortest height, roof is at least 20-30mm higher. They're a bit wider than a metre, considering the entire car width is 1.41m, and they only have the sill and a single skin in the back. I'd be guessing at least 1.2m.
Users browsing this forum: No registered users and 112 guests
