It is currently Sat Jul 26, 2025 12:25 am
 Post subject: Pot Joints
PostPosted: Thu Apr 10, 2014 10:15 pm
Does any one have a reference point as to when pot joints were introduced into the production run?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
 Post subject: Re: Pot Joints
PostPosted: Thu Apr 10, 2014 10:37 pm
Mines sept 74 plate with pots
PostPosted: Thu Apr 10, 2014 10:39 pm
~1973? When the rodchange box superseded the remote box.
PostPosted: Fri Apr 11, 2014 4:03 pm
It wasn't at the same time as the rod change.
I don't have the dates but the engine prefix changed from the 1000 and 1001 to...
1007 = with the rod-change
1009 = with the pot joints
1010 = change diff ratio to 3.44
1015 = ADR27 = 1st Jan 74.
So there was probably 3 different change points for gearboxes in 73 but it was some time before 74!
What we need is the owners of cars with the engine prefix 1007 and 1009 to post their compliance plate dates. (or maybe Winabbey has some other info?)
PostPosted: Fri Apr 11, 2014 5:31 pm
Morris - I've been providing John via email with all the information I know or have documented on the introduction of 'pot' joints (official title is 'offset sphere' joints). I've yet to find any change point data in parts books or fiche that pinpoints it to a chassis number or precise date in 1973, so your suggestion of asking the membership for ADR plate data seems the best approach. John has lots of plate photos in his library so may be able to start the ball rolling on this.
If I find anything else I'll post it here.
Morris - on a related topic I note the Mini Clubman Series parts fiche PUB 7 shows engines with Low Compression as an option for some of the production changes you show above. They have their own unique engine number prefixes, as below. Do you have any knowledge of these optional engines (e.g. were they available for domestic or export)?
Rod Change and Pot Joints - 1011 (a low compression option to 1007 and 1009)
Diff Ratio - 1012 (a low compression option to 1010)
Users browsing this forum: No registered users and 111 guests
