rear bump stops ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=85290 |
Author: | junior [ Wed Apr 16, 2014 9:18 am ] |
Post subject: | rear bump stops ? |
Currently rebuilding a dry rear sub frame, should I re-route the flexible brake line from the top of the arm to the underside so I can run bump stops? |
Author: | drmini in aust [ Wed Apr 16, 2014 1:20 pm ] |
Post subject: | Re: rear bump stops ? |
If you want to run bumpstops, you will need to. Put a hoseclamp round the arm to hold the pipe in position. Instructions are in the comp bumpstop kit. Kc carries the bumpstop kit in stock. |
Author: | junior [ Wed Apr 16, 2014 3:55 pm ] |
Thanks Kev What would you run up front in the way of a bump stop? |
Author: | drmini in aust [ Wed Apr 16, 2014 4:06 pm ] |
junior wrote: Thanks Kev What would you run up front in the way of a bump stop? Standard conical ones. Either dry, or hydro. Do NOT run the comp hydro front ones unless you are going rallying.. they are way too tall. As I found out... |
