It is currently Thu Jul 24, 2025 12:07 pm
 Post subject: new keys
PostPosted: Wed Apr 16, 2014 10:37 pm
https://www.somerfordmini.co.uk/eshop/i ... HzIGTFa0T0
Thats cheaper than getting a locksmith to rekey a lock with no keys
 Post subject: Re: new keys
PostPosted: Wed Apr 16, 2014 10:50 pm
Certainly is. A pity I have NFI what number the door lock and boot lock are. [I carry 3 keys for my car].:cry:
I might have to drive to Mini King to find out!
[edit] My door lock and boot keys are recuts so I've no idea what the numbers are. But they are not the same.
Last edited by drmini in aust on Thu Apr 17, 2014 8:03 am, edited 1 time in total.
PostPosted: Wed Apr 16, 2014 11:10 pm
Numbers are on the barrel on door locks and on the square rod on boot lock and in front on ingition switches
http://www.triple-c.com/How_to_find_you ... y_code.cfm
Thats if no ones played with the pins inside
PostPosted: Wed Apr 16, 2014 11:49 pm
also on the key if you still have an original key... well on mine it is
PostPosted: Thu Apr 17, 2014 7:33 am
I have a few 919 keys here from when we cleaned out me grandparents house a few years ago due to me grandfather going into nursing home
PostPosted: Thu Apr 17, 2014 8:55 am
I Have bunch of photos from when I rekeyed my locks on my clubby (roundies are pretty much the same) I have been meaning to create a how-to for rekeying.
Its easy as
PostPosted: Thu Apr 17, 2014 10:57 am
Ive re keyed a few too you need a few barrels but
PostPosted: Thu Apr 17, 2014 11:07 am
With old lock barrels you can often just use a similar key, especially if they're worn. I can use my key from our '86 hilux on my sister's '92 camry.
PostPosted: Thu Apr 17, 2014 11:26 am
It's also typed with the other car details in the front of the driver's handbook.
You've still got the original driver's handbook for your car, right? :shock:
PostPosted: Thu Apr 17, 2014 11:59 am
As drjbeam implied, you can swap the pins over from other barrels to make it fit the key you have, if you have enough to pick from.
I did that with my boot lock after changing the door locks to Solex. Wish I could've put a Solex on the boot too. :(
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Thu Apr 17, 2014 5:59 pm
To show where the code numbers are stamped...
Earlier ignition switch...
Later ignition switch...
Note the five pins in these genuine locks. :roll:
PostPosted: Thu Apr 17, 2014 10:54 pm
yes I keep it inside a fancy bini handbook holder
