new keys
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85303
Author:  drjbeam [ Wed Apr 16, 2014 10:37 pm ]
Post subject:  new keys
https://www.somerfordmini.co.uk/eshop/i ... HzIGTFa0T0
Thats cheaper than getting a locksmith to rekey a lock with no keys
Author:  drmini in aust [ Wed Apr 16, 2014 10:50 pm ]
Post subject:  Re: new keys
Certainly is. A pity I have NFI what number the door lock and boot lock are. [I carry 3 keys for my car].:cry:
I might have to drive to Mini King to find out!
[edit] My door lock and boot keys are recuts so I've no idea what the numbers are. But they are not the same.
Author:  drjbeam [ Wed Apr 16, 2014 11:10 pm ]
Numbers are on the barrel on door locks and on the square rod on boot lock and in front on ingition switches
http://www.triple-c.com/How_to_find_you ... y_code.cfm
Thats if no ones played with the pins inside
Author:  wallie [ Wed Apr 16, 2014 11:49 pm ]
also on the key if you still have an original key... well on mine it is
Author:  drjbeam [ Thu Apr 17, 2014 7:33 am ]
I have a few 919 keys here from when we cleaned out me grandparents house a few years ago due to me grandfather going into nursing home
Author:  Bubbacluby [ Thu Apr 17, 2014 8:55 am ]
I Have bunch of photos from when I rekeyed my locks on my clubby (roundies are pretty much the same) I have been meaning to create a how-to for rekeying.
Its easy as
Author:  drjbeam [ Thu Apr 17, 2014 10:57 am ]
Ive re keyed a few too you need a few barrels but
Author:  Irish Yobbo [ Thu Apr 17, 2014 11:07 am ]
With old lock barrels you can often just use a similar key, especially if they're worn. I can use my key from our '86 hilux on my sister's '92 camry.
Author:  winabbey [ Thu Apr 17, 2014 11:26 am ]
It's also typed with the other car details in the front of the driver's handbook.
You've still got the original driver's handbook for your car, right? :shock:
Author:  Slugman [ Thu Apr 17, 2014 11:59 am ]
As drjbeam implied, you can swap the pins over from other barrels to make it fit the key you have, if you have enough to pick from.
I did that with my boot lock after changing the door locks to Solex. Wish I could've put a Solex on the boot too. :(
Author:  Morris 1100 [ Thu Apr 17, 2014 5:59 pm ]
To show where the code numbers are stamped...
Earlier ignition switch...
Later ignition switch...
Note the five pins in these genuine locks. :roll:
Author:  wallie [ Thu Apr 17, 2014 10:54 pm ]
yes I keep it inside a fancy bini handbook holder
