weber 45dcoe help
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85321
Page 1 of 2
Author:  clovus [ Fri Apr 18, 2014 3:09 pm ]
Post subject:  weber 45dcoe help
I am almost finished installing my weber but have run into a problem with the acclelerator cable. It does not seem to return after pushing the pedal in. Without the cable it seems to return quite nicely. Here is a photo of the set up.
And the other side of the carb. The trumpets are 26mm if anyone is interested.
Do I need some sort of additional spring return or have I installed the part the throttle goes into incorrectly?
Author:  i got a mini [ Fri Apr 18, 2014 3:26 pm ]
Post subject:  Re: weber 45dcoe help
I got told u need a additional spring on it as the one in the webber is not strong enough
Author:  drmini in aust [ Fri Apr 18, 2014 3:53 pm ]
Yes you need another spring.
Author:  bill.b [ Fri Apr 18, 2014 4:20 pm ]
Also make sure that the spindle that the two butterfly's sit on it not too loose. This will give a rubbish return as well.
Author:  clovus [ Fri Apr 18, 2014 5:52 pm ]
Thanks everyone for the replies. I figured out the cable guide was putting it at a funny angle. I ended up changing the cable linkage to one that sits on top with two return springs.
Author:  aaron [ Fri Apr 18, 2014 6:43 pm ]
Any chance you can post your new linkage setup, I am trying to work out the easiest way to do it.
Author:  clovus [ Fri Apr 18, 2014 7:44 pm ]
Here you go.
I have the accelerator cable coming around the front. There is a bit of a tight bend but the cable seems to move ok. With the two springs the effort required to push the pedal is pretty substantial so I might take one off and see if it suits me better.
On the very top picture there is a brass fitting that looks like as hose gets attached. Is it the hose from the clutch cover?
Author:  gtogreen1969 [ Fri Apr 18, 2014 8:02 pm ]
Wow that's some setup you have there. Should fix your return problem real good.
The brass fitting there would go to a brake booster through a non return valve or through a PCV Valve to the crankcase ventilation. Or blank it off. Depends on what systems you have attached.
Author:  aaron [ Fri Apr 18, 2014 10:23 pm ]
Ahh, yeah I saw those and thought, there has to be a better and cheaper way than that. Reckon I need to play round it. If anyone else happens to want to pitch in a pic of how they run their setup that'd be grand.
Author:  drmini in aust [ Fri Apr 18, 2014 10:56 pm ]
Not a Weber but same linkage fits-
https://www.flickr.com/photos/31275265@N05/9266581508/
Author:  clovus [ Sat Apr 19, 2014 8:30 am ]
I like it Kev,
Looks much better then my second setup, which is really convoluted. The action with yours is in line with the mechanism. Which is why I changed it to the wheel one in the first place.
Author:  aaron [ Sat Apr 19, 2014 9:02 am ]
Kev's setup is pretty Std, but there has to be a simpler setup. It seems very convoluted for what should be something quite simple really.
Author:  Cooper_Matrikon [ Sat Apr 19, 2014 6:05 pm ]
Still installing but my new Mangoletsi has NE impressed. Throttle cable comes over the rocker on the right.
Author:  Cooper_Matrikon [ Sat Apr 19, 2014 6:07 pm ]
60mm trumpets tucked away inside the Ramair if anyone is interested. :)
Author:  clovus [ Sat Apr 19, 2014 8:46 pm ]
Ahh, the benefits of the weber box. No way they fitted with a std firewall on my car. Next mod will be a box using your dimensions.
