It is currently Fri Jul 18, 2025 9:03 pm
 Post subject: rod change housing
PostPosted: Tue Apr 22, 2014 7:28 pm
I am rebuilding my rod change gear linkage.
Its badly worn with up to 6 thou wear in the bushings and rod.
I am pretty sure I have seen someone do a bush and seal modification here on the board
Whats my best option and materials to use for the bushing
Thanks in advance
Kiwiinwgtn.
 Post subject: Re: rod change housing
PostPosted: Tue Apr 22, 2014 10:41 pm
Like other post
Give john at mini kingdom a call he has second hand rod change housings he could post you i was asking him the other day
PostPosted: Tue Apr 22, 2014 10:45 pm
Bernard,
You can still buy new housings in UK I think, but most s/h ones you find are probably as bad as the one you already have.
I would rebush it as I said, if the rest of the housing is OK.
PostPosted: Thu Apr 24, 2014 9:03 pm
I went to the seal place and they had replacement bushes in stock.
I also brought a seal to protect the bushes.
The bushes simply tapped out and its just like new.
I swapped the rod end to end to resolve the wear on the shaft
And the best bit it only costc $11.00
PostPosted: Thu Apr 24, 2014 10:09 pm
Good one is it a public holiday over there tomorrow for anzac day
PostPosted: Fri Apr 25, 2014 6:55 pm
Yep holiday today. Spent it in the garage working on the mini
