Right hand fuel tank
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85415
Author:  Scoop [ Fri Apr 25, 2014 12:37 pm ]
Post subject:  Right hand fuel tank
Hi guys, first time post.
I have a right hand fuel tank that I would like to install into my Deluxe project. What do I need to do to mount the tank in position? Can I make a paper template from the left side to get the position for the right side hole? This is about the last hurdle I have before I can put some paint on. Any guidance would be very appreciated.
Chris
Author:  drmini in aust [ Fri Apr 25, 2014 1:05 pm ]
Post subject:  Re: Right hand fuel tank
That's how I did it when I fitted one to my wasaMatic.
You can buy a RH tank mounting kit but I just shaped a bit of wood for underneath, and used a standard tank strap.
Author:  TK [ Fri Apr 25, 2014 1:05 pm ]
No the hole for the tank is not a mirror image of the left. Sitnlo posted the correct measurements, do a search.
Author:  TK [ Fri Apr 25, 2014 1:10 pm ]
here you are;
viewtopic.php?f=2&t=84662&p=932763#p932763
Author:  Scoop [ Fri Apr 25, 2014 1:30 pm ]
Just found the measurements. Will go and cut a hole and see what happens!
Thanks for all the help and info.
Author:  Bromley [ Wed May 07, 2014 5:48 pm ]
How did this work out for you? I was going to make it easy on myself and just make a reverse template of the left side. Please tell if there is any reason why this method will not work.
Author:  timmy201 [ Wed May 07, 2014 5:50 pm ]
TK wrote:
Author:  junior [ Wed May 07, 2014 6:22 pm ]
timmy201 wrote:
TK wrote:
Wonder if the plastic tanks made by Paul Gulson are any different, his instructions are to make a template from the LHS tank.
Author:  Scoop [ Wed May 07, 2014 7:38 pm ]
I used those measurements and it looks pretty much right. I cut the hole a little bit smaller so I can adjust to suit. I had bought a gulson plastic tank previously but it didnt come with any instructions. I sat that in but didnt like the look of it so its back on the shelf for the moment. Might go back to repairing the metal one.
Author:  low n blown [ Thu May 08, 2014 9:03 am ]
you can do it but your tank wont fit through the hole. That's why there is something wrong with this method.
Author:  Scoop [ Sat May 10, 2014 10:00 am ]
The metal bracket on the LH floor, is it required on the right hand side? I have a rusty leyland parts shell that I can cut it from. Also on the back of the seat panel there is a bracket welded on there and a captive nut setup. Should I weld these bits on?
Author:  drmini in aust [ Sat May 10, 2014 10:19 am ]
There is a RH bracket you can buy, but I used a block of wood.
To attach the RH strap I just drilled thru the seat back and used a nut & bolt.
Author:  Scoop [ Sat May 10, 2014 7:14 pm ]
Spent a few hours tinkering in the boot area today. I managed to get the right hand tank hole correctly located and the tank is mounted. Looks good. Even the plastic tank I have looks fine now so might I run that.
