It is currently Fri Jul 18, 2025 9:14 am
 Post subject: Drive shafts?
PostPosted: Fri Apr 25, 2014 6:35 pm
Just a quick question . If I was to put a rod change pot joint gearbox in a mini with rubber Uni's are the drive shafts the same ?
Cheers Anthony .
 Post subject: Re: Drive shafts?
PostPosted: Fri Apr 25, 2014 6:49 pm
Quick reply.. NO.
PostPosted: Fri Apr 25, 2014 7:49 pm
Thanks for that I will look for some pot joint drive shafts
PostPosted: Fri Apr 25, 2014 9:47 pm
Ok my extension to that question...drums or discs, any difference to the lengths of drive shafts on Baron's question? Being, rubber unis with discs changing to pots that had drums but wanting to use the same discs off the remote box with On the rod with pots? Does that make sense?
PostPosted: Fri Apr 25, 2014 10:24 pm
Doesn't matter whether using drums or discs. Both shaft types fit both CVs.
Pot joint shafts are different lengths to the others and their inner end spline etc is different..
