jprior2912 wrote:
Wow thanks for you reply!
It's mainly the rear rubber I'm having an issue with - When you say it needs to be cut at the top and centre, what do you mean exactly?
Thanks
James
Most rear rubbers are UK size, made to suit their Mk2 on, and they have a wider rear window than ours (which are all UK Mk1 sized).
Front ones are all the same and don't need cutting.
You can also buy this screen rubber by the metre from rubber shops- eg Grippy rubber in Sydney, or Clark Rubber.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
