Clubby van i.d https://www.ausmini.com/forums/viewtopic.php?f=2&t=85550 |
Author: | Scoop [ Sun May 04, 2014 8:10 am ] |
Post subject: | Clubby van i.d |
Hi guys, Just bought a Clubman van for a daily driver. Its a 8/73 but I cant find out what it is. The vin plate has the stamping MINI 021A2V2 M10 Any idea what it was? Thanks Chris |
Author: | Morris 1100 [ Sun May 04, 2014 10:30 am ] |
Post subject: | Re: Clubby van i.d |
It is a Leyland Mini Van. It was built with an 1100 motor. |
Author: | Minimadmarty [ Sun May 04, 2014 10:30 am ] |
021 = Leyland Mini A = Manual 2V = 2 door van 2 = Trim level 2 M = 4 speed floor change manual gearbox 10 = 1098cc motor 8/73 The date the car dispatched from the factory |
Author: | Mr Orange [ Sun May 04, 2014 6:10 pm ] |
It's marked exactly the same as mine, except mine is 7/73. You and your new fangled one-month-later-than-mine van! |
Author: | Scoop [ Sun May 04, 2014 7:26 pm ] |
Thanks for that. I bought it without and engine so I wasn't sure. Has rod change tunnel and pot joint cv ends so I assumed that side of it. I have a couple of 1100 engines here so that works out pretty good. What does trim level 2 mean its meant to have? It has blue seats with head rests and blue seat belts but there is no dash cluster. There is also a heater. |
Author: | Mr Orange [ Mon May 05, 2014 2:43 pm ] |
The others might correct me here, but I'd be fairly sure it was a direct change originally. Mine was, though it's rod and pot now. Checking for the patch in the floor pan would let you know anyway. Mine was otherwise stock - had heater, two gauge cluster, no radio and that's about it. Seats were high back like yours. Sorry, can't supply you any other information - my door cards are made out of old beds, floors are riveted chequerplate and carpet is definitely home made! |
Author: | Scoop [ Mon May 05, 2014 8:02 pm ] |
Thanks for the info guys. Very helpful. There is no patch in the floor. Rod change floor for sure. I will have to do LH foot well panel. Bit of rust there but the rest of the floor all good. |
