What does XE mean in the 9FXEY engine number prefix? https://www.ausmini.com/forums/viewtopic.php?f=2&t=85576 |
Author: | winabbey [ Mon May 05, 2014 5:31 pm ] |
Post subject: | What does XE mean in the 9FXEY engine number prefix? |
I'm away from home and can't access the material that would answer this question that was asked by a colleague. Hopefully Morris 1100 is not far away. ![]() |
Author: | Morris 1100 [ Mon May 05, 2014 6:25 pm ] |
Post subject: | Re: What does XE mean in the 9FXEY engine number prefix? |
Sorry to say I don't really have a full answer for that one. The XE somehow refers to a 4 syncro gearbox. All the Cooper S codes are silly. Sticking a 9 in front of them to try and fool the FIA that the 1275 is really a continuation of the 997. |
Author: | drmini in aust [ Mon May 05, 2014 6:51 pm ] |
p71 of John Parnell's book "Original Mini Cooper and Cooper S" just states `Introduction of 4 speed all-synchromesh gearbox'. |
Author: | miniron [ Tue May 06, 2014 8:47 am ] |
The XE means its a 4 synchro close ratio box ie Cooper S ratios. When you compare it to the 3 synchro Ta/Sa boxes where the T means standard ratio and the S means close ratio/Cooper S and the a means 3 synchro, then the X probably refers to close ratio and the E means 4 synchro box. RonR |
Author: | simon k [ Tue May 06, 2014 3:42 pm ] |
the gearbox case should have XE stamped on the front too |
