Which clutch housing https://www.ausmini.com/forums/viewtopic.php?f=2&t=85578 |
Author: | guna mk1 [ Mon May 05, 2014 6:26 pm ] |
Post subject: | Which clutch housing |
Hi all Does anyone know if a rod change clutch housing will work on a 4 synchro remote gearbox or do I have to use the correct early housing . Thanks |
Author: | justminis [ Mon May 05, 2014 6:38 pm ] |
Post subject: | Re: Which clutch housing |
Provided the idler gear is a match then yes. Not the other way around as the rod change transfer housing has an extra bit cast into the housing at the bottom to prevent shift overthrow. |
Author: | guna mk1 [ Wed May 07, 2014 12:09 pm ] |
Thanks Steve |
