It is currently Wed Jul 30, 2025 2:02 am
PostPosted: Sun May 11, 2014 9:10 pm
Hey guys and gals,
The floor cross member is rusted all the way along the front of it so I am planning on replacing it.
I am thinking of welding some braces before I remove it.
How is it welded in? Are there spot welds all of the way along it or..?
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Mon May 12, 2014 8:29 am
Yes it's got spot welds along the flanges,
You need to either drill them out, or cut the crossmember out above the flanges then grind the remaining flanges/spots away.
PostPosted: Mon May 12, 2014 12:01 pm
The flanges is where my rust is at.
I was wondering how they would have originally spot welded that piece in - especially the spot welds closer to the middle of the car.
I will plug weld the new piece in then.
