Radiator Number stamping https://www.ausmini.com/forums/viewtopic.php?f=2&t=85660 |
Author: | modaddie [ Tue May 13, 2014 12:26 am ] |
Post subject: | Radiator Number stamping |
hi Guys, just wondering if the number stamping on the radiator support for the 1969 Mini Cooper S has the same size font and style from the first to last number? ie is the YG2S4 the same size as the 5??? number stamped after? thanks in advance |
Author: | Morris 1100 [ Tue May 13, 2014 5:54 pm ] |
Post subject: | Re: Radiator Number stamping |
From memory they are usually two different sizes, depths and fonts. |
Author: | modaddie [ Tue May 13, 2014 7:41 pm ] |
oh ok, the font on my mini is smaller on the yg2s4 and the number stamping after is slightly larger font |
Author: | winabbey [ Tue May 13, 2014 9:49 pm ] |
See here - viewtopic.php?f=2&t=85668 |
Author: | simon k [ Thu May 22, 2014 9:43 am ] |
modaddie wrote: hi Guys, just wondering if the number stamping on the radiator support for the 1969 Mini Cooper S has the same size font and style from the first to last number? ie is the YG2S4 the same size as the 5??? number stamped after? thanks in advance just a pedantic point on that, if you have a car with YG2S4 and then 4 digits starting with a 5, then there's something dodgy going on, those numbers didn't go past 3000 (actually 2919 or something) and my numbers are the same font I think |
Author: | modaddie [ Fri May 23, 2014 9:41 pm ] |
oops my bad, it starts with a 5 but is only 3 numbers 547 |
Author: | gtogreen1969 [ Fri May 23, 2014 10:00 pm ] |
Early one. Does it have a body plate like the MK1 S |
Author: | modaddie [ Fri May 23, 2014 10:22 pm ] |
no its only got the stamping on the radiator support, and a number stamped in the channel above the wiper motor |
Author: | gtogreen1969 [ Fri May 23, 2014 10:44 pm ] |
Thanks. I think that was the case for the first 6 months or so. I have seen a couple with Mk1 Body Plates but they have all looked too clean to be original. Probably the owners wanting to have a plate on there for looks. |
Author: | Bubbacluby [ Sat May 24, 2014 9:27 pm ] |
With my GT I know it is YG2S8 looks like a set stamp evenly spaced etc, and then the numbers afterwoods are in a different size and look hand stamped |
