Lock Set?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85663
Author:  Jbrucem1 [ Tue May 13, 2014 1:08 pm ]
Post subject:  Lock Set?
Have tried a brief search with no luck, what does everyone do regarding matched lock sets (ignition, doors and boot)? are they even available or do i need to purchase new handles. dont have original keys for any so need all new?
Coming from a mustang restotarion where everything is available 10/times a minute!
Many Thanks
Author:  Harley [ Tue May 13, 2014 1:28 pm ]
Post subject:  Re: Lock Set?
Minis never had the ignition key matching the doors / boot.
A locksmith should be able to make the doors / boot match for you.
Author:  justminis [ Tue May 13, 2014 2:07 pm ]
Early round nose minis, those without steering locks, did have matching ignition/door/boot lock keys. The Mk 2 S I bought off the original owner in 1977 did. This doesn't include the later Rover minis obviously.
Author:  Jbrucem1 [ Tue May 13, 2014 3:33 pm ]
Can you purchase a barrell set somewhere (in aus referrably) that will do the lot in one go?
Author:  Aussie Brian [ Tue May 13, 2014 4:44 pm ]
I took the lock barrels from door and boot to a locksmith and had them altered to suit the ignition. It was a simple task for them and it is so nice when you aren't fumbling with different keys all the time.
Author:  Bubbacluby [ Tue May 13, 2014 5:53 pm ]
Not hard to disassemble and rebuild yourself. You will need a bunch of other locks though for spare bits
Author:  Mick [ Tue May 13, 2014 7:39 pm ]
There was a triple set available for ignition, door and boot (Roundnose only) I bought a set a few years ago. I thought it was easy to find it again, but it is not. There is only a kit for two door/boot barrels.
Saying that, if you get two, then it should be simple enough for a locksmith to make the ignition barrel (which is different) suit the door and boot.
https://www.minispares.com/product/Clas ... o%20search
