Street suspension settings https://www.ausmini.com/forums/viewtopic.php?f=2&t=85671 |
Author: | Hanra [ Wed May 14, 2014 7:55 am ] |
Post subject: | Street suspension settings |
Just curious to see what others run in terms of ride height and camber settings etc for the street. I found a handy camber gauge app for iPhone which works well. With my new adjustable lower arms, the minimum amount of negative camber I can achieve is -2 degrees. My car is also quite low. I note I have -.5 degree of negative camber on the rear wheels, not sure if I should increase that? What do others run? |
Author: | drmini in aust [ Wed May 14, 2014 8:00 am ] |
Post subject: | Re: Street suspension settings |
-1.5 to -2.0 deg is fine on the front, -0.5 to -1.0 is fine on the rear. I run -1.5 front, -1.0 rear, and 2mm rear toe-in (for stability). |
Author: | Lillee [ Wed May 14, 2014 12:06 pm ] |
-1.0 at the rear is what I run. Some other factors come into play for the front, when running a hard wall tyre, I found -1.5 was the best, but on soft wall AO32R's I now run -2.5 to get the same handling as I did on -1/5 with A008's. AO32R's on -1.5 felt slushy not very pointy. -2.5 will wear your tyres out faster too I think but for you and me Hanra (we'd both be lucky to run them more than 500miles per year) wear is a non issue! |
