Cleaning calipers
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85702
Author:  Fiji [ Fri May 16, 2014 5:57 pm ]
Post subject:  Cleaning calipers
I've removers mine off the front end whilst replacing hoses etc. I just want to give them a small clean up . Can I soak them as is in some hot soapy water or do I risk getting water past seals etc.
Author:  peterb [ Fri May 16, 2014 6:02 pm ]
Post subject:  Re: Cleaning calipers
as long as hose holes a blocked, soaking them is fine. Try scrubbing with jiff or similar.
Author:  drmini in aust [ Fri May 16, 2014 7:07 pm ]
Don't use degreaser to clean them. If you need a solvent, use metho.
Author:  Fiji [ Fri May 16, 2014 7:16 pm ]
Yeh holes are all blocked I'm keeping them out in case back of caliper won't be seen.
Sweet as Cheers
