Wheel problem https://www.ausmini.com/forums/viewtopic.php?f=2&t=85703 |
Author: | peterb [ Fri May 16, 2014 8:42 pm ] |
Post subject: | Re: Wheel problem |
You can get stepped wheel nuts that have their own washers. Try a good wheel supplier or net. |
Author: | womble99 [ Fri May 16, 2014 8:52 pm ] |
peterb wrote: You can get stepped wheel nuts that have their own washers. Try a good wheel supplier or net. So change all rims to use different nuts? I am guessing these washers are just a press fit? |
Author: | gtogreen1969 [ Fri May 16, 2014 9:02 pm ] |
Is there still a machine shop at work? |
Author: | womble99 [ Fri May 16, 2014 9:06 pm ] |
There is sort of a machine shop at work......... cut backs you know...... |
Author: | jprior2912 [ Fri May 16, 2014 10:39 pm ] |
I recently bought some new Contessa wheel nuts off of Frank Tonito - e-mail: [email protected] 02 4773 3022 100 Eaton Road, Luddenham NSW 2745 These nuts have the washers on them - if you just want the washers I'm sure he'd sell you the washers, he's a top guy and has been manufacturing wheel nuts for 50+ years. |
Author: | drmini in aust [ Sat May 17, 2014 9:48 am ] |
I had a wheel missing 4, so I machined some up. Sorry I don't have the dimensions now, but they are easy to make- anybody with a lathe could make them. Material is just mild steel, I used some 1020 bar. |
