It is currently Thu Jul 31, 2025 5:42 am
 Post subject: Wheel problem
PostPosted: Fri May 16, 2014 6:08 pm
I have started refurbishing my 10" rims and have noticed the washer inserts have been removed whilst sandblasting :cry: This probably wouldn't have been an issue if I had noticed at the time however I didn't and now I am stuck with one wheel missing the inserts...........
Now for the stupid question, are they available and if so anyone know where I can get them from?
CJ
Missing the inserts
With the inserts
 Post subject: Re: Wheel problem
PostPosted: Fri May 16, 2014 8:42 pm
You can get stepped wheel nuts that have their own washers. Try a good wheel supplier or net.
PostPosted: Fri May 16, 2014 8:52 pm
So change all rims to use different nuts? I am guessing these washers are just a press fit?
PostPosted: Fri May 16, 2014 9:02 pm
Is there still a machine shop at work?
PostPosted: Fri May 16, 2014 9:06 pm
There is sort of a machine shop at work......... cut backs you know......
PostPosted: Fri May 16, 2014 10:39 pm
I recently bought some new Contessa wheel nuts off of Frank Tonito -
e-mail: [email protected]
02 4773 3022
100 Eaton Road, Luddenham NSW 2745
These nuts have the washers on them - if you just want the washers I'm sure he'd sell you the washers, he's a top guy and has been manufacturing wheel nuts for 50+ years.
PostPosted: Sat May 17, 2014 9:48 am
I had a wheel missing 4, so I machined some up.
Sorry I don't have the dimensions now, but they are easy to make- anybody with a lathe could make them. Material is just mild steel, I used some 1020 bar.
