Finding switches in the dark https://www.ausmini.com/forums/viewtopic.php?f=2&t=85720 |
Author: | timmy201 [ Mon May 19, 2014 7:42 am ] |
Post subject: | Re: Finding switches in the dark |
In our work truck the end of the switch illuminates when then are switched on. I'm sure you could wire it up to light up with the lights circuit instead. Like this: http://www.ebay.com.au/itm/Car-SPST-Ill ... 51e&_uhb=1 Or maybe even these. You could paint most of it with a black paint and have the red showing on the end or the bottom? http://www.ebay.com.au/itm/SPST-12V-TOG ... 7f7&_uhb=1 Or you could just fumble around in the dark by memory |
Author: | Diesel27 [ Mon May 19, 2014 8:42 am ] |
Glow in the dark tape is effective. |
Author: | wallie [ Mon May 19, 2014 9:04 am ] |
ive seen a few UK cars use push buttons that illuminate they look quite sleek http://www.electricalcarservices.com/Sa ... 0-185.aspx |
Author: | awdmoke [ Mon May 19, 2014 3:23 pm ] |
Here are the three methods I've used- 1. Memory fumble 2. Wait for a car behind you to light the the dash 3. A neon wire under the dash. Gives off just enough reflected light off the carpets to spot the dash |
