speedo cable troubles
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85741
Author:  mitchell evans [ Tue May 20, 2014 5:41 pm ]
Post subject:  speedo cable troubles
Just been having some troubles with the speedo and cable in a 68 deluxe when I bought the car the speedo didn't work
Just put the new cable in and still not working the cable isn't even spinning at the speedo end as I disconnected to see if it was the speedo
would it be something in the gearbox making it not spin?
any help would be appreciated
Author:  clovus [ Tue May 20, 2014 6:18 pm ]
Post subject:  Re: speedo cable troubles
It sounds like it. There is a nylon bush on a spindle that spins around inside the gearbox. The speedo cable fits inside the spindle. They wear out easily so could be spinning freely, or it could be jammed. I would try changing the speedo cable first to ensure it's not kinked, just cas it's easier. If not you need to remove the metal clamp that holds the speedo end unit in place and check it. I will see if I can find my spare one and take a photo for you after dinner
Author:  clovus [ Tue May 20, 2014 6:20 pm ]
Forgot to mention, the place in the gearbox where the speedo cable goes into is not easily accessible. Removing the carby (carbies) makes it easier but it is still challenging.
Author:  drmini in aust [ Tue May 20, 2014 6:31 pm ]
Take out the 1/4" bolt next to the bottom cable end, wiggle the cable bottom nut around without undoing it. The adaptor plate will lift off with the cable.
Author:  mitchell evans [ Tue May 20, 2014 6:58 pm ]
It's a brand new speedo cable I also replace the little rubber bush inside this part below
Author:  drmini in aust [ Tue May 20, 2014 7:10 pm ]
Try the speedo cable end in the shaft that drives it.
A bit of wear and they don't drive.
Author:  mitchell evans [ Tue May 20, 2014 7:26 pm ]
clovus do you mean the bush in the photo? Bit of a bad photo orange looking part?
Cheers doc I will try that
