Dumb Question of the Day
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85862
Author:  BKozan [ Thu May 29, 2014 2:39 pm ]
Post subject:  Dumb Question of the Day
No nuts, bolts, screws or nails. Can't see any clips, grommets, latches, jubilees or clamps.
I've pulled pretty hard, but maybe I need to pull harder. So how in the hell do I remove the Handbrake Handle from my '98 Rover?
Author:  Harley [ Thu May 29, 2014 2:42 pm ]
Post subject:  Re: Dumb Question of the Day
It's just pushed on, but because its rubberised its hard to remove.
Ive seen the odd one glued on too - not sure if that was factory or not though.
Author:  Convertible Mini [ Thu May 29, 2014 3:06 pm ]
Try warming it up with a heat gun to make it release a bit.
They are fitted tight.
Author:  BKozan [ Thu May 29, 2014 3:13 pm ]
Thanks guys. I think I'll buy a proper heat gun on the way home. The Missus' hair dryer just isn't cutting it these days.
Author:  Harley [ Thu May 29, 2014 3:20 pm ]
Try twisting it - that often helps.
Author:  gtogreen1969 [ Thu May 29, 2014 4:34 pm ]
You need to stick your tongue out just a little.
A filter strap can help break the seal.
Author:  taztiger4 [ Thu May 29, 2014 4:40 pm ]
If its rubber, try peeling up a bit and squirting air thru a small nozzle up it !!
Works for motorcycle hand grips
Author:  BKozan [ Mon Jun 02, 2014 11:52 am ]
Yep, mine was glued on. After some prying, heating and clever use of fencing wire I managed to slide it off. I installed my fly-away handbrake and had some fun on a rainy Sunday in an empty carpark. I also found out that my cable needs some adjusting, as the passenger side didn't want to lock quite as nicely as the driver side. Good times.
