Will 14 inch Wheels fit a Clubbie?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85865
Page 1 of 2
Author:  Minimadmarty [ Thu May 29, 2014 4:26 pm ]
Post subject:  Will 14 inch Wheels fit a Clubbie?
I'm looking at fitting a set of 14 x 6 inch wheels with 195/60 R14 tyres to my 78 Clubbie. Will they fit without too much modification? (I have flared arches as I'm currently running 165/60 R12's).
If not possible what are the largest wheels that will fit? Any photo's of examples greatly appreciated 8)
Author:  Morris 1100 [ Thu May 29, 2014 4:45 pm ]
Post subject:  Re: Will 14 inch Wheels fit a Clubbie?
You can fit 15 inch wheels to a Mini. The problems start when you try to fit tyres.
By my estimates your current tyres have a diameter of 19.9" (502mm) and you want to fit a tyre with a dia of 23.21" (589mm)
How much space is there between the front of the rear tyre and the trailing arm? You need 44mm.
Author:  drmini in aust [ Thu May 29, 2014 4:46 pm ]
13secmini put a set of 14s on his `Daihatsu MiniK'. They fit, but I dunno what the tyre profile or size is.
Author:  Harley [ Thu May 29, 2014 4:57 pm ]
14" rims with 195/40/14 tyres are comparable to 175/50/13 wheels - problem is the tyres are VERY difficult to obtain. I think only TOYO make them and you'd have to get them from Japan.
Author:  Minimadmarty [ Thu May 29, 2014 5:00 pm ]
Slightly misled you all sorry..... My current tyres are 165/55 R12's therefore the diameter is 480mm. The trailing arm distance is only 38mm! Don't think the 14 inch idea is going to work!
Author:  Kennomini [ Thu May 29, 2014 5:59 pm ]
I think you'll foul the front guards with 6" wide tyres when you turn. I'm pretty sure they need to be thinner.
Author:  wallie [ Thu May 29, 2014 6:34 pm ]
force racing do a 15x5" rim but good luck in finding rubber bands to fit them and start from 1000pounds to buy, there was a guy here in SA who had 14" rims he bought tires from japan IIRC
Author:  Phil 850 [ Thu May 29, 2014 6:57 pm ]
These are 17x7" on an 850. It does have significant modifications for these to fit. Refer to post MNIWRX in engine conversions. Sorry, not sure how to do a link.
Phil
Author:  Minimadmarty [ Thu May 29, 2014 7:07 pm ]
Cheers Phil I have seen your thread re: MNIWRX and very impressive. I love the Bini rear lights and flat fuel cap but I'm afraid that type of work is way way beyond my abilities! I think the 14 inch wheel idea was just a crazy idea!
Author:  mad-mk1 [ Fri May 30, 2014 1:29 am ]
Harley is 100% spot on. I had them on my 850, same guard mods to the front as you need for 13s and the rears need a trim of the trailing arm bleed nipple dust guard plate thingy!
Author:  drjbeam [ Fri May 30, 2014 5:46 am ]
Phil 850 wrote:
Morris Mini beetle should have put on vw beetle rear lights looks good
Author:  Irish Yobbo [ Fri May 30, 2014 11:43 am ]
I have seen 15's on a mini in amagazine somwhere. They required the guard to be cut though - not sure you want to go to that extreme. Did look pretty good though.
Author:  JC [ Fri May 30, 2014 12:03 pm ]
viewtopic.php?f=40&t=84259
Author:  Davo111 [ Sat May 31, 2014 9:14 pm ]
mutant mini used to run 14's but I think he got his from Germany, see if he will pop his head up on this topic.
Author:  leyland78 [ Sun Jun 01, 2014 7:22 pm ]
I have also got a clubbie with 175/50/13 . They were rubbing the guards , so I cut the panels for more room . Then stuck the flares on can't tell they have been cut. The 14 inch wheels would look awesome.Here is a couple of photosImageImageImage
