It is currently Sat Jul 19, 2025 6:47 am
PostPosted: Sun Jun 01, 2014 8:05 pm
So my S driveshafts are missing the thick circlipthat butts up against the CV.
Part no: 17H8597.
Unavailable.
Can you get them? Where?
How do you put them on?
Is it easier to find new shafts?
Need some soon ish.
Any advice appreciated.....thanks.
Now with 2 extra ports!
PostPosted: Sun Jun 01, 2014 8:46 pm
My question to this is :
How do get them off an existing drive shaft ?
Can they be re-used ?
The alternative is these :
http://www.minispares.com/product/Classic/Drivetrain/Driveshaft/C-BTA1267.aspx?0803
http://www.minispares.com/product/Classic/Drivetrain/Driveshaft/C-BTA1268.aspx?0803
PostPosted: Sun Jun 01, 2014 9:17 pm
Thanks for the link. I had spotted those while looking for the circlips.
I think the large circle on my shafts cracked in a few pieces and disintegrated .
Also don't know how to get them off another shaft...
PostPosted: Sun Jun 01, 2014 9:21 pm
You don't mean the retention detent clips? They're made of thin piano wire and can be made yourself.
PostPosted: Sun Jun 01, 2014 9:23 pm
No not the thin clips.
The larger clip closer to the inside end of the spline.
PostPosted: Sun Jun 01, 2014 9:37 pm
I've got a spare shaft here, I'll suss the clip out in the morning.
PostPosted: Sun Jun 01, 2014 9:40 pm
Thanks doc.
Is there a difference between Cooper S shafts and non S shafts?
Eg higher spec metal/hardening process?
Can I use standard shafts?
PostPosted: Sun Jun 01, 2014 9:58 pm
Cooper S shafts are higher spec steel but I used std 850 ones on my 1st 1220>1275 Mini, just put the hardy spicer joints onto the splines.
S ones have a raised diameter part way along the shaft, also their length is very slightly different. But std shafts do work OK, particularly on a road car. If rallying I'd like S ones at least.
